I have a Y32 Cedric thats going through an engine transplant (VG30DE) at the moment, and i have been quoted $2000+ for the seals, hoses, waterpump and timing belt. And a 6-8 week wait
Not sure if its Nissan Australia or my mech. that is ripping me off, but i'd like to try and source the parts using a parts importer (even if i'm not being ripped off i'd like to get the parts quicker than 6-8weeks!)
Are there any services that can help me with this? Specifically i need:
A "VSR Pack" with all engine seals in one
All engine hoses (heater hose, bypass hose, top and bottom radiator hoses, any other hoses that are engine-specific)
Waterpump
Timing belt
Or should i just go through Nissan in rockdale or wherever it is?
VG30DE was used in the Z32 300ZX sold in Australia, so things like water pump, timing belt and engine gaskets will be available across the counter at Nissan - might even be able to get them from Repco, etc. Even if they have to be ordered from Japan the standard turn-around time from date of order is 2 weeks - not 6-8 weeks. Maybe your mechanic has pissed off the local nissan parts department guys in some way.
All you have to do is take your VIN number into your local Nissan parts dealer and he can look up the stuff you want in FAST.
Thanks for that. I called up John Robinson Nissan in Rockdale, and after supplying my details, he told me that half the parts were available locally with only the VRS pack and some of the hoses needing to be ordered. But you are right, its only 2wks turnaround for the Japanese parts, and the price was a little over 1/2 of what i was originally quoted <_<
I am waiting to hear back from a Japanese parts importer though, because they may be able to get them cheaper again...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
