Thanks Dennis , it looks like a major engineering feat dosen't it ............
Seriously though for about 1/4 - 1/3 of the weight of a DR30 radiator the R32 GTR one offers probaby 40% more cooling capacity , remember those cars made nearly 280Hp standard in a mild state of tune and do not overheat .
Recently some mental giant wanted to argue the toss over copper vs aluminium as a heat sink medium for radiators , I will agree that copper has the legs on ally but remember this important fact . Copper radiators ares stuck together with solder which has a high lead content and you guessed it - lead is a very POOR conductor of heat energy . Most would say "so what , the tanks are soldered on the core end plates" . They would be right but how do they think the gills are stuck to the tubes ? right again with our poor contucting solder . You could say this fin to tube insulation is a great way to drop heat sink efficiency - but it was a cheap way to manufacture radiators for a long time .
Aluminium rad cores are furnace brazed and transfer heat in the water tubes to the gills much more quickly and efficiently , there is less resistance to airflow through these later cores so its a win win situation .
Cheers A .
Edited by discopotato03
Cheers  A .
Mate,
You got me, I'm going to buy a BRAND NEWIE for my PNV, as I have the DR thermo fans I'm going to mount them on the back and dispose of the motor driven fan mounted on the water pump.
For a few minutes of stuffing around, I'm gunna have the best.
Gotta mean somethin in the power gain dept.
To quote an old friend that used to race Toyota Celicas when he found the all metal GT bumpers vs Ozzy LT rubber/metal were 5kg lighter "It's gotta mean somethin"
Cheers,
Dennis
My Bluebird also used the DR30 fans and shroud but it was not by choise . I would never remove a viscous hub engine driven fan particularly on a turbo car . These fans force feed air through the engine bay keeping the underbonnet temps down which is important with red hot hair dryers lurking within .
All thermo fans do is dump hot air in the bay when the water temp is already a bit high . They'll never move as much air as the conventional one can . Incidentally the viscous hub takes the load off the engine when things are nice and cool .
With thermos the water thermostat is not the only temperature control device and it should be , as I said the fans only come on when EVERYTHING is hot .
If you still think the power loss is significant use a larger water pump pulley ie L20B or FJ20, if its running constant high revs the water pump will be cavitating anyway so kill two with one .
Cheers A .
P.S All RB powered Skylines use an engine driven fan , the GTR fan itself would be better than the 22 yr old L series wind mill - RB26's red line at 8000 , nuf said .
Cheers again .
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
