Hi Skyliner's, I am selling off the remainder of a 95' R33 Gtst Coupe that was unable to be complied under the new RAWS regulations. I have many parts left, ie Interior, some mechanical, rear windscreen and qtr glass, etc.
Email me what you need, [email protected] and I'll endeavour to get back to you in the evenings.
Leave me your email address if you want more info, including price.
SJ
Edited by rdirty32
https://www.sau.com.au/forums/topic/85797-wrecking-r33-coupe/
  • Replies 50
Hi Nath,
The reason I haven't listed all of the parts is that I'm not sure as to what parts I have kept after stripping the car. The body shell had to be destroyed by law, which left me with various parts that I am now clearing out. I would love to be able to list all of the parts, but it would take me a few days to confirm exactly what I have, and lets face it, there are some parts that will never be required by anyone.
The way I see it is, make me an offer on a part that I have, and then everyones happy.
I hope this explains my situation.
Cheers, SJ
Do you still have any of the following;
- Handbrake cable & Lever
- Pedals
- Clutch master cyl
Did it have good suspension? If so, how much for the rear only?
Prices pls, thanks :P
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
