Ive done the swap aswell and you will find a god increase in power for the same boost.
If your not using a bc make sure you swap over the Actautors as the Rb25 one is set around 5psi from memory and the RB20 is set at 10 psi i think.
As jas/slo32 said its quite easy to do.
Does the RB20DET's compressor elbow that connects to the IC piping bolt up to the R33 RB25DET turbo?
I know the R34 Compressor covers outlet is slightly larger than the RB20DET's. As a result you have to use the R34's elbow.
Has any one taken to time to measure the Comp wheel of an rb25 turbo?
I have a few approx measurements..
R34 RB25 Turbo.
Inducer - 49mm
Exducer - 66mm
Approx Trim - 55
VG30DET Turbo
Inducer - 46mm
Exducer - 63mm
Approx Trim - 54
The R34 RB25 and VG30 turbo's share the same slightly larger turbine housing. Apparently it measures some where around the .7 a/r where as the rb20/25 is around the .6 a/r. I was told the sizes by a turbo shop.
When I pull my rb20det turbo off I will measure its wheels and also compare.
Edited by Cubes
R34 RB25 Turbo.
Inducer - 49mm
Exducer - 66mm
Approx Trim - 55
VG30DET Turbo
Inducer - 46mm
Exducer - 63mm
Approx Trim - 54
yeh you need the rb25 turbo elbow. rb20 doesnt fit
no.. tried it.. bolts holes don't match up that well, and smaller diameter hole on the flange. You sort of *could* get it to work via redrilling, but could cause problems.
all i can say on that is.. good luck!
I don't know why people always take them off when they sell them as they can't be too useful for anything else, but you tend to find a large number of the rb25 turbos without them, and they can be a bitch to track down. ;)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
