(Item: Brand new Ford XR6 turbo, same as Garret GT3540, GT35R internal 1.06 wastegate exhaust housing
Item Condition:Brand new
Reason for Selling:Too big for my application
Price and Payment Conditions:$1650 firm
Extra Info:Will bolt to standard RB25 manifold (T3 flange) perfect for RB25/30 engines.
Contact Details:PM or post here
15/3/06 - Looks like turbo is now sold!
great turbos, only difference between this and the garrett GT35/40 1.06 rear is the *slightly* smaller compressor wheel and different A/R on the thing. with a GT40 compressor though, it's not really an issue, they're capable of big airflow!
Yes turbo is for sale. The only difference between this turbo and an aftermarket GT35R (GT3540) is the smaller A/R compressor housing. The wheels are identical and are not smaller.
Please don't post rumours or unvalidated facts as this is what led me to purchasing one of these turbos in the first place .... to find out it is exactly the same wheel sizes. Hence why it's too big for my purposes.
Hi,
It looks like a really nice turbo. Im after something that will bolt on and offer more power.
What kind of applications will it suit?
How laggy will it be on a rb25?
What power output is it capable of?
My car has excedy clutch, blitz ic, full exhaust, pod, power fc and blitz ebc.
So once I upgrade my turbo I will need to get a z32 afm and a fuel pressure reg or better injectors.
Thanks
Mark
If you look up on www.turbofast.com.au you can see that they rate this size turbo and exhaust housing at 700hp.
Fatz(Pete) has one on his RB26, I think he posted it makes full boost in the late 4xxxrpm?
If using it on an RB25 I would strongly recommend cams, AFM, injectors, intercooler etc. It should make an easy 300rwkw+.
Thankyou for your reply :P
I think this turbo could possibly be too big for my needs, Im after something that will make full boost in the late 3xxxrpm's and make mid to high 2xx kw range.
Sorry if I have inconvenienced you at all.
P.S Would you know of something suitable at a similar price???
Thankyou
Mark
just going on what the garrett supplier told me when he measured the wheels. the one he measured was definately smaller than the standard GT40 compressor wheel but not by much. maybe there's different revisions of the ford turbo out there? :P
Edited by StockyMcStock
good turbos
abit laggy however i found mine had a echaust leak that i will finally be fixed theis week will report back if theboost resonse increases
these turbos are making 400rwkw on other cars
pete
Will check to see if the lines are the same diameter and thread, it's just a Garrett GT30 core so it should be similar. Not sure about the dump pipe, there might be a couple of companies offering the dump to suit Ford which may be similar.
Should be more than capable of making 300kw @ all 4 wheels, if there are already people making 400 in rwd mode then 300 @ awd would be a shoe in.
  • 1 month later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
