turbo still for sale?
i have an rb25det s1 with stock internals, intercooler, powerfc, standard afm and standard injectors (getting new ones soon)
how much power would i expect to make? i'd probably run it de-tuned at low boost til i upgrade the rest of my gear to match the turbo..
u reckon it should run 220rwkw+ til i get new afm?
also, it would bolt straight on, ye?
  • 4 weeks later...
  • 3 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
