hey, i dont think you should import, as you will not know the condition of the car until it arrives. fair enough u will save some money, but best to buy one locally if you know exactly what condition of car you want. its not like there is no choice locally...
once again ill mention, in pics cars always look good. even if the paint was shit in real life it will look good in pictures.
since that car was complied under the new system i very much doubt it would have been in an accident, so i would not worry about that.
so yeah, dont import if u are picky with condition, also who wants to wait months....
its just that ive been hearing bad things about the guy selling it...thats not something you want to hear when there is the chance that you'll be giving him $17k
also, everyone keeps telling me how much choice there is. the truth is, if you want a white car, you're set! there's so many to choose from its not funny (its really not funny, it shits me!)
i wanted a black series 2 with good kms. not so low that they're bs, but not so high that the cars on the way out. manual. not worked off its head. doesnt have holes n shit drilled everywhere for gauges etc....
there really isnt as much choice as everyone would like to think
i can understand if u want a black one, they are not common at all, i have only seen a couple around..
just got check out that red car and see how that goes before getting worried!
yeah i might mate...im not to keen on the importing thing...i always get a car im looking at checked by both a mechanic, and panel beater before i even think about buying it...
you dont even need to wind back you can just change the speedometer over out of a crashed one that had low k's at the time of its crash. so you can never be gauranteed of k's. but just driving the car will let you know. drive a few before pruchasing. thats the best way then you will feel what good ones and bad ones drive like.
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
