Hey fellas, heading down to the Bulla Pub, in Bulla, its behind the tulla airport.
"Lesbian Lickout" nite 2nite, $5 entry and u watch about 5 XXX acts, most of them lesbian(maybe its all of them, cant remember).
Mens Gallery aint got nothing on this place!! B)
Shows start at 8pm, (sorry for the late post)for more info:
ADDRESS:
80 Bulla Rd.
Bulla
(if heading west its on your right with a servo to its left)
PH:9307 1182
Cheers
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/
dont care what quality they are... theyre strippers... been there done that and never going back. the only thing ur going to get from there is a raging hard on and no where to release it.
strippers are the biggest waste of money around... if u want a cock tease get some porn... at least then you can jack off without beeing bashed by some big bouncer lol
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1558738
Yeah, my bad, now i know what angle hes coming from. Im with u in that sense, id rather go Pros than spend money for a lappy. I went cos a whole bunch of us were catching up, and thought why not do it there. I left 1/2 through. Had to make some fone calls to release this fustration ur talking about :O
Thought id jut post it up and spread the good word though!!
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1559128
I found this, so i thought id post it up for u narky!! :)
They are from HEAT Adult Entertainment
Herewas  the 1st bird, shes on the right. Seen these 2 lesbian act pretty HAWT!
lol, i get your point about a waste of money, but fark. $5 for an actual live sex show is ridiculously cheap. a normal club costs at least double that just to get in, and bar 20 etc is like $15, and that just gets you inside.
$5 = live lesbian sex = bargain :D
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1561296
Damn they aint that bad, live theyre much better. Beleive me, it aint that bad!!
not even that bad in the pics mate....maybe some of these guys just wish they were guys dressed up like ladies?
$5 is an absolute steal
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562043
Damn i wonder how lose they would be lol (being broad minded persons). You could probably get a larger sensation by banging air...
they're strippers mate...not prostitutes...
the fact that they strip doesnt automatically make them whores or loose etc
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562621
your right it doesnt automaticaly make them whores or loose...
they were probably whores and loose before they became strippers, so the transition was normal for em :)
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562758
Actually they had nice tight and clean pouches :)
Looks u cant even get a feed for $5 bucks these days let alone 2 birds eating each other out 5cm away from your face hehehehe
mate, dont worry about these ankle grabbers here that wouldnt wanna watch that...next time its on, and your going, i'll join you. for $5, why the hell not.
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562986
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
