Hey fellas, heading down to the Bulla Pub, in Bulla, its behind the tulla airport.
"Lesbian Lickout" nite 2nite, $5 entry and u watch about 5 XXX acts, most of them lesbian(maybe its all of them, cant remember).
Mens Gallery aint got nothing on this place!! B)
Shows start at 8pm, (sorry for the late post)for more info:
ADDRESS:
80 Bulla Rd.
Bulla
(if heading west its on your right with a servo to its left)
PH:9307 1182
Cheers
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/
dont care what quality they are... theyre strippers... been there done that and never going back. the only thing ur going to get from there is a raging hard on and no where to release it.
strippers are the biggest waste of money around... if u want a cock tease get some porn... at least then you can jack off without beeing bashed by some big bouncer lol
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1558738
Yeah, my bad, now i know what angle hes coming from. Im with u in that sense, id rather go Pros than spend money for a lappy. I went cos a whole bunch of us were catching up, and thought why not do it there. I left 1/2 through. Had to make some fone calls to release this fustration ur talking about :O
Thought id jut post it up and spread the good word though!!
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1559128
I found this, so i thought id post it up for u narky!! :)
They are from HEAT Adult Entertainment
Herewas  the 1st bird, shes on the right. Seen these 2 lesbian act pretty HAWT!
lol, i get your point about a waste of money, but fark. $5 for an actual live sex show is ridiculously cheap. a normal club costs at least double that just to get in, and bar 20 etc is like $15, and that just gets you inside.
$5 = live lesbian sex = bargain :D
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1561296
Damn they aint that bad, live theyre much better. Beleive me, it aint that bad!!
not even that bad in the pics mate....maybe some of these guys just wish they were guys dressed up like ladies?
$5 is an absolute steal
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562043
Damn i wonder how lose they would be lol (being broad minded persons). You could probably get a larger sensation by banging air...
they're strippers mate...not prostitutes...
the fact that they strip doesnt automatically make them whores or loose etc
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562621
your right it doesnt automaticaly make them whores or loose...
they were probably whores and loose before they became strippers, so the transition was normal for em :)
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562758
Actually they had nice tight and clean pouches :)
Looks u cant even get a feed for $5 bucks these days let alone 2 birds eating each other out 5cm away from your face hehehehe
mate, dont worry about these ankle grabbers here that wouldnt wanna watch that...next time its on, and your going, i'll join you. for $5, why the hell not.
https://www.sau.com.au/forums/topic/86158-bulla-pub-2nite/#findComment-1562986
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
