Red tops (there are two red versions, NICS and ECCS) have a 12 port head as opposed to silver tops 6.
Reds have a smaller turbo. Reds have low imp hose tail injectors, silver has high imp O ring type.
Reds are older and from the 31 series cars and parts are a lot scarcer.
Factory VS factory setup the silver has more power. Engines alone with identical ancillaries I reckon there would not be much if anything at all in the power difference.
so how much power difference are we talkin about here? about 20kw?
more than that, i think it's like 40kw
the ECU on the NICS RB20 is really poo poo, to get anything worth while from it you need some re-tuning, head work and a bigger turbo etc etc
Got rid of mine before the car even hit the street
the redtop head vs the silvertop is different in many ways, also the eletrics in the heads are prone to failing - IE CAS sensors etc.
Try finding a CAS for a redtop as there are 3 different ones :D
Its not worth the hassle
stick with silver
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
