YAY New Cooler Is In
  • Replies 92
Originally posted by inark
oooooooooooo nice one denham! 183 at the wheels!!
that will be fun in the wet :D or dry for that matter
it was fun this morning pulling out of a petrol station onto princess highway and infront of a truck and nearly ending up facing the on coming truck!:D
sounds to me like your own clothes will soon have their own pee stains in them! still dunno about the hair though?
Originally posted by nismoR34
nice cooler and numbers too! forgive me if you already stated but is it a custom made cooler? or GTR cooler? etc And if you don't mind, what price?
have fun...
hks cooler with 2.5 stainless steel ceramic coated piping which helps 2.
