  • Replies 40
Can I ask. What did you do wrong? Because that sounds to me like a pretty major mistake x3. Mostly to the point you would have to be losing the company some signficant money. Because if your one of their biggest earners, then they would have to be nuts to get rid of you.
It could posibly be scare tatics?
I agree with DD.
but, as one door closes another will open - it's an old cliché but I beleive it to be true.
Anyway, good luck mate!
If your a good salesman, you won't need much luck.
good salesman always fall on their feet. :P
amen to those words.
im sure it will all turn out in the end :)
at least you now know not to trust any of them...bloody managers..... :P
50K jobs are nice work if you can get it mate. Im your age and i dont get anywhere near that (even tho i went to uni doing 2 science degrees) :D
Why not grab a 35-40K per year job that has better conditions in the short term? Surely you can cut back abit on your lifestyle options??
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
