Where are you based?
I'm reasonably sure Tempe Tyres in Sydney used to advertise RT215s in 18" for less than $500 a corner. The site's been overhauled, so they no longer have the prices.
However, if you're expecting RT215s to perform like a proper Comp-R semi slick, you're going to be disappointed. They're a very grippy street tyre, but even Falken's marketing drones advertise it in the radial section, rather than motorsport class.
i use the RT215s 245/17s, not bad but they are no RE55. if you want semi slicks go the whole hog and get some RE55s or something like that. the RT215s are ok, but the rubber is no where near as soft/grippy as the main semi's out there.
What are they being used for?
One thing people tend to forget is that when semi's are cold they are damn un-grippy. And getting good heat into them on the streets isnt easy.
If its a kick ass street tyre your after then the Aziens are probably the go. I think the new Aziens - the 615's are due out in October. But if its for the track then the RE55's are the go.
What Snoman said.
I assumed from you asking for "semi comps" that you were after a motorsport tyre, for which the RT215s are not suitable.
However, if you're just after something for "daily driving" street use, the RT215s will do a better job. They've got better wet weather grip and don't require as much heat.
Its not impossible to get Comp R semi slicks up to temperature on the street, but generally it'll only be if you go on a fast-paced cruise or whatever. However, every time it rains you're in for an adventure. And the noise will drive you insane.
what im trying to acheive is an all round tyre that will give the best of three worlds?? road , track and strip. is this an impossible dream. i suppose id probably be on the the road 90% of the time though. what do i do spend spend spend on two different sets of tyres or do i buy a good road semi like the rt215s??? would love to hear what you guys think? would 245/40 semis be anygood on the drag strip and the road??
mate if you are on the road 90% of the time i would suggest buying a good road tyre. or if you can afford it buy a 'reasonable' road tyre and a set of semi slicks. I drive on RT215s on the road but i don't do many kms at all so wear is not really that much of a factor. I really think you are better off with two sets if you can afford them, 1 for road, 1 for track/strip.
depends what you are doing.. if you are against true track warriors, they'll have full type R compound and you'll wish you had something a little better...esp in a powerful RWD (like it looks like yours is)
But compared to the occasionals, who who run cheap ass road tyres on the track, then they'll be wondering why you are doing a bit better than they are :) So its all a compromise and what you want to achieve.
You are doing yourself a disfavour running 18's, as even if you go cheap roadies, and cheap track tyres, its still going to cost $$$
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
