Thank you to those who have placed an order
Anyone wishing to pay using credit card or paypal can now purchase heir set online via our website at the URL below
http://www.justjap.com/bridestyleseatspecial.htm
Cheers,
Steve
  • Replies 175
Posted Images
We have some stock available of the black with grey centre, black with red centre and black with blue centre - all of which are ready for immediate pickup or dispatch from our Kirrawee store.
:P
Hi steve,
I put an order in for a pair of the all red seats just wondering when they will be delivered, I am in Melb.
Thanks
Jamie
Hi Jamie, we are waiting the container to arrive which is due in around 3 weeks, once the seats arrive, all pre-orders will be dispatched immediately.
If you have any further questions please dont hesitate to ask
Regards,
Steve
Great service guys I have the seats thanks, now how do I put them in? I was hoping them would come with some sort of instructions, obviously they are designed for professional installation. Anyway I have ripped one of my standard seats out and taken the bits off it that I think I need. However, the mounting brackets are pretty much stuck to the sliding mechanism on the seat. Any suggestions, ideas or is there an online manual somewhere?
mspec, how does the black with grey centre go with the your car - im assuming its white. also are the seats comfortable to sit in, whats the material like.
They look really good for $350 a pair, they also go very well with my interior and yeah my car is white :) Installing them is a bit tricky but I am getting there.
mspec, wouldnt mind posting pics of the seats inside the car would you. i also have a white line and thinking of getting a combo colour other then black and red which seems to have alot pre-sold whilst the combo colour im assuming it already in stock ready to deliver.
haha once I get them in I will post some pics, I will only have time to get one in before the next track day and I'm not even going to bother with the other one just yet. To be honest I found it much easier to install my clutch than these seats :)
Interested in a pair of avail ones. How long does delivery take to WA? So the total cost is $430 ?
Thats correct Keefy
LoL. Err. So what colours are avail now? I want the leaver kind for reclining. Also, how long would it take for delivery to WA? Last thing is how much work is needed to get them fitted onto a R33 ?
Could you please tell me how much for post to Canberra??
$430 delivered
Cheers,
Steve :P
Are compliance plates required for these seats here in QLD?
Or can I just rip out the standard R33 GTS-T seats and fit these with the universal rails that come with it?
Hi mate, you are best to check the regulations in your state in regards to fitting. The seats include universal rails that need to be modified and adapted to your existing rails to bolt in, which usually requires some welding.
We recommend having your seats fitting by a competant workshop.
Cheers,
Steve
Hi steve,
have the seats arrived yet?????
Cheers
Jamie
Hi Jamie, they are on the water as I type, not long now.
Steve
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
