  • Replies 175
Posted Images
payment sent , please addvise when shipment has arrived , and anyone who has installed them please put up some "how to" pics !
Hi mate, thank you for your order. Your payment has been received and confirmed and your seats will be dispatched immediately once we receive them.
The ETA for the container at this stage is still the 10th of this month.
If you have any further questions please dont hesitate to ask
Cheers,
Steve
ill take a pair of black ones too when u get them back in if they have the quick latch
Hi Leigh, we are expecting the black seats in both lever and winder type.
We will update this thread the moment the container arrives.
Thanks
Steve
Has anyone got the seats to fit properly with the generic rails in a skyline?
When i got a different set a few years ago i ended up getting some second hand bride seats for the skyline and then modifying the bolt location as the generic rails would not work as they sat the seat 2 low, the belt buckle is apart of the stock rails and the floor plan where the seats bolt to are at different elevations making trying to modify generic rails hard.
Hi Jaqule - the container arrived Friday and we are busy preparing to send out all the sets that have been pre-sold. If you are interested in a set please act quickly to avoid missing out.
Here is a picture of the all red seats with lever reclining mechanism
We have not done an in-house installation of these as this is the first complete container load we have received but we may have some pictures soon after we fit these to our new drift project car.
Regards,
Steve
Can you get them in leather?????
Sorry, we dont have the Bride style in leatherette type im afraid.
Steve
Hi mate.
Trevor processes and packs all online orders for shipping to customers. If you would like to check the status of your order please feel free to call him direct on (02) 9545 0532 - Alternatively, if you tell me who you are I can check for you. Its virtually impossible to followup orders with nothing more than a forum username.
Regards,
Steve
Sorry , it's Beau Best 0402220733 , you spoke to me about 2 hours ago about the balck seat with red centre ?
Good afternoon all,
We have now filled all backorders and have 5 pairs of all black bride style seats and 7 pairs of all red Bride style seats remaining in stock - get those orders in quick!
All seats use a lever type reclining mechanism
Cheers,
Steve
Hi guys, thanks for all your orders
ALL BLACK BRIDE STYLE SEATS ARE SOLD OUT!
We should have another container load in around 4 weeks.
Anyone wanting to secure a set from the next shipment is encouraged to get your orders in ASAP.
We sold out our last container load in 4 days
Regards,
Steve
Jacob, please give Trevor or Darron a call asap on (02) 9545 0532 to sort this out.
Apologies for the error
Steve
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
