  • Replies 175
Posted Images
What size are they? I am typical small japanese style person size and i dont have larger friends to be passengers.
Do you have a picture with someone sitting in them?
Hi Alex, we dont have any images showing people sitting in them, but the approximate dimensions are as follows:
Overall Height: Approx 90cm
Widest Point: Approx 53cm (shoulder to shoulder)
Internal width at rear of base: Approx 33cm (actual seating area)
Internal width at front of base: Approx 36cm
Regards,
Steve
  • 4 weeks later...
  • 5 months later...
im itnersted however wandering if you can get rails for a 33gtst or apprently bride rails ? i got told to get a aftermarket seat fitted ur lookingat around 400 bux
Kennedy: The forum special is still available, though we are waiting on more stock of the red Bride style seats, we only have all black in stock currently.
Sammie: The cost of installation tends to vary depending on who does it. We recommend using a reliable and competant workshop or fabricator so you dont pay through the nose. We have supplied genuine Bride rails for some customers however they are quite expensive and comparable in cost to having the universal rails customized.
Hope this helps, if you have any further questions please dont hesitate to ask.
Cheers,
Steve
PM Sent.
Are you getting in the black seats with the grey inserts too?
Hi Sam, we have no plans to get more stock of the black with grey inserts at this stage im afraid.
We will arrange to have a set of the black Bride style seats put aside for you, please pm me your full name so we can get this finalised.
Cheers,
Steve
  • 1 month later...
bueller?
I really want to see one of these fitted on the drivers side.
I've done it but I havent got photo's. Gimme a couple of days.
The fit was a nightmare. I just ended up modifying some second hand genuine recaro rails to make it fit and so I could have the option of bolting the seat belt buckly to the car rather than the seat. Everything you see in the photo's is what you get. You dont get an sandwich plate to go between the seat and chassis
Hi Steve,
I am interested in 2 sets as I want to customise the car and run a set of these seats also in the back instead of the current rear seat. The kind I am after is as per your picture with the black and blue seats ? Do they come in Vinyl or Leather ?
Can you provide me with a price and delivery to Melbourne please ?
Cheers,
Sam
Hi Steve,
Cheers,
Sam
Hi Sam, unfortuantely we only have the Bride style seats available in black or red at this stage.
They come in mesh type fabric only.
I will pm you a total price including delivery shortly.
Cheers,
Steve
Using genuine Recaro or Bride rails makes the job a lot easier. We found that only minor changes are needed if you use off the shelf rail kits, ie on the seat we tested with genuine Bride rails we only needed to elongate a few holes and that was it.
Steve
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
