I would like to know who people have purchased Boost gauges off and who installed it. I could possibly install it myself but I spent years working on my Valiant that doing fiddily crap like that is just not fun anymore. I heard that Autobarn is the place to go, but can you get them cheaper elseware and get them installed at the same time?
thanks in advance
Chris
https://www.sau.com.au/forums/topic/86748-where-can-i-get-a-cheap-boost-guage/
NOT AT BRISBANE TURBO AND TUNING
i got charged over 300 bux for a shitty vdo gauge that still didnt work propperly and then they wanted more to fix it (used to make an annoyign noise when registering boost sometimes)
motsons ended up fixing it for us
id give them a try
one of our friendly forum members I am sure can do it for a 6 pack of beer or something like that.. I would if I was up in bris. Its quite easy.
A workshop stuffed up a boost gauge install.. :D lovely.. haha
Dont have one for sale but when you do get one,
They are EASY as to install.
Just use the vaccume line that goes to your in dash boost gauge and stick that into your other boost gauge *assuming you get a mechanical one* From memory it was up the back kinda, near the firewall on the driver's side.
Then to wire it up, use the power source from the headlight dimmer switch, coz then your gauge dims with your instrument panel !!
OOOOHHH aAAAAHhhhh !!
Just earth it to some bolt on the firewall, or on the steering coloumn.
**see pic, thats where mine used to sit when i actually had a skyline ;)
good luck, have fun
Yeah they are so easy that even I installed my $30 el-cheapo boost guage in my old r33.
And for reference I am a dumb clutz who nearly chopps fingers off when trying to work on a car, so if I can do it, anyone can! :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
