Hey all you vics out there....
I'm organising a dyno day for those who want to do some power runs.
$50 for a couple of power runs. Perfect opportunity to check the power and mixture on your beast. We can work something out if you want some tuning done also.
Please e-mail or call me on 0411 878 961 if you want to book your spot now.
PLACES LIMITED
Doc.
https://www.sau.com.au/forums/topic/8693-dyno-day-1-feb-2003/
  • Replies 111
It's a place called Goodguys Performance in Bayswater.
It's state of the art Dyno Dynamics with all the latest software.
Are you definate on dynoing festiva? I'll have to find out if they have FWD rollers....
Dyno Day is from 8am till 12 midday.
Goodguys is in Bayswater
Any car welcome, nissans preferred.
Please PM to confirm
INARK: Morning Dyno Definate?
LOWLUX: Definate?
AIT: Definate?
A couple of others have expressed interest.
Doc.
Last Dyno day I went to cost $30 per car..? was last year [02]
I am half interested but my ride is mostly stock atm, will wait and see if there is still a spot closer to the day. $50 seems a bit steep to me.
Yes I am a tight :shake: :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
