nice pick up stewy, please dont hurt the front and rear lights
i actually have some ceffy tailights in the C33 from a mates missile he left in the hall when he left, i'll bring them back as well as these ones. i'll make sure all of the exterior parts are ripped off before i hit things haha, headlights i dunno, i kinda need to see at night lol
oh and it's RB25 also, can't win em all haha, but it's got a 25/40 which will make for fun power, at least it's not a stock RB25, i'd kill myself if i had to deal with their boring as f**k power delivery haha, it may come home to go on my RB20 :thumbsup:
looks cool, is the plan to go wall riding and run a muck? i dont see why peeps dont just buy damaged cars for matsuri....
because in japan there's bugger all value in the shell itself (for cars like S13's, R32's and ceffy's etc), most of the value of these cars is in the mods and drive gear, a mint shell with aero etc will fetch a bit more, and and undriveable shell will fetch a bit less, but the stuff in between there isn't a huge price difference, in the end if one car is loaded with goodies for cheap, that's the one you buy.
If ur keen in selling that 2540 let me know nisskid. Are you also bringing the car back to aus or just stripping it over there?
i'll probably bring it back as a half cut to strip here, i'm kinda tempted to put the 25/40 on my RB20 as i'm getting such good results with the 25/35 on mine, people piss and moan about gutless 20's but i look at my torque curve, but i'm looking in a thread on ns where they are all praising some results for a few 230rwkw from a SR20 with cams and everything, and the turbo hits full boost later than mine, yet mine keeps going to 250rwkw, and more importantly it revs higher, safer, which gives me a wider band of power. more power/torque earlier, peak, and for longer, yet RB20's are a shit engine?
shhhhh , they will go up in price :ph34r: .oh and i found a pic of probably the only r32 4d more damaged than yours :nyaanyaa:
Edited by toffy
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
