i dont know why it was done. Some say it works better and i also read it has something to do with the last cylinder .
But his car works well has a couple other mods run well
Check out our group on facebook
https://www.facebook.com/profile.php?id=519324105&sk=photos#!/groups/210592938965823/
yes but the rb26 front facing intake mani works well.
and the sr20 comes from factory facing that way.
so there's a way to make them work and also your ment to get a remap after installing one as AFR aint right
Edited by Dan_J
got proof/dyno sheets to sheets to show an rb26 plenum on a 20 or 25 makes a difference?
and an sr20 and rb26 were designed by nissan to work with a forward facing intake manifold thats why they work on those motors, rb20/25 were designed to run with a side facing plenum coz it obviously works
your right so therefore a front facing plenum can be designed from scratch with ecu tuning to run right. not saying everyone should get a hectik front facing intake.
just saying
Edited by Dan_J
Aaaages ago i sold it , i swapped it for a s14 s2 , then swapped that for a r34 which is my daily . poor old girl has popped 2 gearboxes by 2 different owners since i sold it , the vskf's are too heavy for skids with a 20 box :P , it (the laurel) is in the members ride section somewhere
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
