It's his car in Japan. What's your point?
Love that thing Stewy, kinda how mine will end up if my other pair of wheels ever turn up.
Does he live in Japan at the moment?
Kind of lost.
Apparently his car? Photo taken in JP. Profile says he lives in SA.......
stewy like many other drifters around the world travel up to japan for drift matsuri / or just a general drifting holiday. seems to have a good connection or two as he makes it look too easy, turning so many fresh cars into missiles LOL
Edited by Dan_J
stewy,
demon camber much? thats just for stance right or did it slide well with what looks like 5deg of camber ?
it's not much more than your average touring car really, it's just you can see it as the wheels don't sit far inside the guards, and unlike open wheel cars you have a body to line them up with so you notice the tilt more. it's probably in the region of 6-7 degrees camber, i used to run that on my 32, i will dial some out once i get bigger flares for the front, probably to around -5, the main thing being it has lca's which are 50mm longer for clearance (it runs modded knuckles and big lock).
Kind of lost.
i lived in japan for a while, got a residency card which allowed me to rego cars in my name, and lived in a town where you could rego cars without a parking permit (very rare). this is my street car in japan, however it also gets drifted on the track/street. i don't live over there any more, but i do go back and forth, this car gets stored at either ebisu or down in osaka depending on where i end up at the end of my trip.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
