Is that your 33?
sure is, had it a few months now
Ceffy getting some attention kriss? What size/offset do you run on the 33?
yeh done GReddy plenum, Q45 TB, Tomei rail, bigger injectors again, just needs cooler piping and tune now
wheels on the 33 are 17x9 +17 all round with 225/45's, will get some better pics once new front bar is on it
Do you have adjustable arms and shit? Mate has a 33 four door but he's retarded with wheels so I'm sorting that bit. Only thing he wants is cst's but he's nuts about scrubbing and stuff. Trying to work out wether to get 9 +15's all round or play it safe to avoid his whining and get the +30's. Be 215/45's on the front but no adjustable arms.
Good to see the Ceffy getting some attention! I'm too broke to do anything on my laurel.
+15's will be poking and definitely scrub. Depending how low it is too, without guard work the tyres will be touching the rear guards. If dudes paranoid about rubbing would be better off sticking witth +30's they will still look decent enough,
Looks tough, need more pics!
thanks man, fresh painted type M bar goes on tnight so will take some pics this weekend
nah all standard arms man, 9 +15's will be fine, mine doesnt rub at all anywhere and the rear even has room to go to a 235/45 which i will be doing, just go 215/45 fronts and he'll be sweet
haha nah no build threads for me on SD, 33 will be up for sale soon anyways i want another R31, QLD raceway is deff on the cards though this year maybe
just for peice of mind this is my mates sedan with exactly same size wheels as mine but hes alot lower and he runs 215 front and 235 rear, with full car load of people it still doesnt rub, also all standard arms
7F7EC3C2-8790-4FAD-ACAA-647F52DBD39E-208
4A0CC30B-4C04-4487-A436-73FF00A4FF24-208
0B599AE8-82D0-49A3-A096-EAE6960BCCA8-208
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
