So today i went somewhere to get something, and i was sitting on a hill in D.
I wanted to try and find a house and i thought it may have been behind me. I forgot the car was in D but i let my foot off the brake, the car started to slowly roll backwards and then it gathered like a good 15km/h or so.
Then, thinking i am putting the car in R (please dont ask how i managed such a big screw up), i put it in 2.... i rolled for a bit more and then the car stalled!
I put it in park, turned it on and then found the house i needed and parked.
The first time i stopped, i was in D and had the brake fully on. The car was making a woo woo woo woo woo noise at a period of about three woo per second.
Then i put it in N and revved it and it didnt make the noise...
So then i got a friend to put it in D and push the brake and i listened in the engine bay. Thinking it may have been my new timing belt i listened in that area, but it sounded like it was coming from the turbo. Then when i listended to the turbo it sounded liek it was from else where...
Anyway, so i concluded that my auto box is on its way out and i screwed up a gear or something and that i should take it easy.
BUT, the plot thickens. This happend this morning at 11am, since then i drove another 100km and now, i noticed the woo woo also happends like, between gear changes... BUT, now if i am in N and i rev the car at exactly 2500RPM +/- 500RPM, i can get a similar belt rubbing noise? So i am thinking the woo woo between changes is due to the 2500RPM thing
Anyway, anyone got any ideas? I just got my timing belt replaced by a reputable workshop around here, i just hope it isnt rubbing on the cam cover, can i inspect this somehow myself? I dont care if my auto box is on its way out, because i am converting to manual really soon anyway, but i need to be semi certain it will hold up at least you know, another few weeks...
If i just replaced the auto box for another auto, cheap stand in for now, what box would i need to buy?
Thanks for any input fellas,
Alex (worried)
Edited by AlexCim
https://www.sau.com.au/forums/topic/87154-noises-from-transmissionsomewhere/
Oh also, the car still holds fine to redline, with no hesitation.
Doesnt seem to be down on power either and the noise goes away above 3,000RPM, on the spot and on the road. (id think the sound from a timing belt rubbing would get worse?)
The hill was relativly steep, probably a good 20 degree incline
But regardless, i think i just found out my stagea has ~120,000 on the clock, not ~70,000 that it had when it came from japan...based on a service sticked i found on the door, gotta get it translated..
Anyway, ill keep everyone posted with my manal converson
I don't think its anything to worry about. My mate is a mechanic and he replaced the timing belt on my Stagea around 2-3 months ago and it starting making that noise straight away. He reckons it is the newer type timing belts and this is usual for them (I can't be sure, but I think he said something about an increased amount of carbon or something that they are putting in the newer belts). He had a S2 R33 and he says it made the same noise after he put a new timing belt in that too and that it goes away after the belt wears in a bit.
Anyway, I just drove my Stagea from Darwin to Melbourne and back. I sat on around 150-160 kph most of the way between Darwin and the SA border, there and back and covered about 12,000 kilometres on the whole trip. Its still making that noise but it didn't give me any problems at all and still hasn't.
I hope this puts your mind at ease.
Cheers ..... Craig
Yeh, i get a definate noise from the engine at about 1750RPM, but i also get a noise from the transmission...
Whatever, manual conversion is all being organized now, should be all done with soon even if something is wrong or not :)
But thanks for that info actually, it did put my mind at easy a bit (about one noise at least)
Cheers ..... Craig
Sorry to hijack thread but craig how much did it cost you in fuel to Melbourne as I am thinking about driving to Brissy in the new year.
Cheers ICE
Cheers ICE
No worries Shane,
I didn't keep a real accurate record, but I'd say that I spent about $1K on fuel just for the trip down and back ie. $500 each way.
One thing I did notice though, is that when I was doing country driving down there, ie. up to Falls Creek etc., I was getting around 550-600 km out of a full tank. Must have been a combination of the colder, thicker air and the fmic I think.
Anyway, I was going to give u a call over the next couple of days, cos' I've got the same problems with my tyres and the camber that you had. Talk to u soon.
Cheers .... Craig
This might sound stupid, but where is the trans fluid on the stagea? I see the atessa fluid bottle, but where is the trans?
Or, is attessa the trans??
Photos if possible..
hey alex, not thats for the tranfer case ONLY which is the rear half of the gearbox, and the gearbox auto fluid is totally seperate. just a note that the fluid bottle in the boot is totally seperate fluid to the actual transfer case, and it only is used to push the actuator on the back of the gearbox (same as a clutch slave cylinder pretty much) which presses a large arm onto the tranfer case clutches to activate the front wheels.
if i remember rightly so, auto dipstick is on drivers side behind the plenum next to firewall (i think thats right as i got rid of the auto before i had to check the fluid ;) )
also have the engine running while u check the auto trans fluid level :)
good luck
Brad
Edited by StageZilla
There is no transmission fluid bottle, that's a power steering reservoir. The transmission fluid is held in the gearbox, just like the engine oil is held in the sump. The dip stick for the auto trans is at the firewall almost directly behind the inlet cam cover. You check it with the engine running (not stopped like engine oil). In the picture, it is down almost directly the convoluted wire insulator behind the inlet cam cover. It is a redish plastic ring, lift it up and the dip stick will come with it.
Hope that helps
:D Cheers :P
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
