you wouldn't have any bonus in that case and your speeding ticket will not help you a great deal. your only option would most likely be to buy the car under your mums name and be on her policy again. it'll end up being the cheapest that way.
otherwise try just cars. they'll be the only ones that'll talk to you pretty much.
here's a list of some insurance companies to try
http://au.msnusers.com/gts25tskylinepics/i...insurance1.msnw
ps. did i mention how much i hate them?
https://www.sau.com.au/forums/topic/8723-insurance/#findComment-127902
Out of interest which one of the lads do you know ? PM me if you'd rather ...
To answer your question, every company can do it ... the real question is will your employer allow you to do it. The product works on the concept of salary sacrificing but is certainly much more than that.
There is a misconception that salary sacrificing means FBT reporting to be done by the employer = time & money on their part.
With ProsperCar this is certainly not the case and there is basically 0 % admin required from an employer’s perspective. This is the main hurdle that employers have an issue with (and one that there is really no issue with in the first place :() When employers find out it's really just as simple as them splitting an employee's pay by setup of a direct debit, which once setup remains constant throughout the term, most just ask what they have to do in order to get it going.
We usually find that once one employee is set up, most of a company's HR / Payroll will follow, as well as other employee's. Main reason being once they see how it works, how simple it is and how much they could be saving, they can't wait.
It is really so much more effective than anything else out there, be it due to the insurance or the ease of having all costs of running your car combined in one payment or the savings you receive on all those costs you'd usually spend in any case to run a car due to the way in which it's packaged with your salary.
I show people figures each day to run a car entirely which they have trouble comprehending. When I informed a client today he'd be looking at approx $1,300 for insurance on a car a little over $70k ... his first question was if I was talking on a monthly basis :(
I can't help but feel I'm ranting :D I'm out -
... before I forget, if anyone has a direct query they'd rather have answered personally --->
James @ Prosperion
nite all ..
https://www.sau.com.au/forums/topic/8723-insurance/#findComment-135647
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
