  • Replies 135
theres so little friction that theres not a lot of wear on the tyres (relavitvely) but if you can put some cheapies on the back, do it.
We have raced 1 on 1 round the skidpan before, each person started half a track away from the other, and it was first back to the starting point after 3 laps, but it turned into a grip elimination race which was poo. Dont know if we will do it again. We do time trials for sure :P
does not sound like the video venue to me.
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-149027
We are going to video as much as we can....
pete (aka revlimiterboy) will be back down to dorifto the track one handed again....
and I am in training so definatly count two cars from rockhampton.... Jays is a bit of an issue... have three cylinders and all.... don't know if the water will get into the hole in his piston....
anyway.... we are definatly in... no questions asked.... and we'll have a support crew big enough to rebuild a motor if needed.... should be fun... Is it worth going to broadwater for a cruise after the meeting.... I reckon it would be definatly worth a look but I hear the cops are gnarly these days.... not that we want to play up or anything....
and yeah hopefully there will be heaps of good video action....
looks like MRE has got the dorifto down to an art....
incase you can't tell I just can't wait to go playing legal dorifto for safe long amounts of time.... AWSOME>>>
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-149275
hey slip...
are we still waiting on a date....
can you try to make sure it doesn't clash with the SR20 day...
actually... you should try to make it so that one day it's your wet skid day and the next it's the SR20 day....
just there is a huge crew coming from rocky and we are planning on coming down twice... but if it was at all possible that it could be just one weekend... it would be awsome... cause everyone would come from up here....
but yeah i understand it's all due to availability and maybe that means that some guys don't want to do both events so close together....
although from what I can make out MRE won't be scared...
just pete wants to go to the dry day....
a whole heap of us want to go to the wet day and it would be a shame that most of us can't make both....
just see what you can do slip... thanks a heap....
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-157650
I am told it is at the end of march at willowbank raceway....
but please don't ditch your event because of it.... I really want to go to the wet day for the fun.... I don't like the idea of breaking my car in brissy and having to find a way home....
where as pete is totally hooked on the idea of destroying his new toy at the SR20 day..... go figure??!!
anyway.... I found out about it because it is on the events callander of the raceway.... I think MRE should be able to hook you up with some dates...
please try to organise them so they are the same weekend and there will definatly be some very excited rockhampton import boys cruising in brissy.... we would love to organise a saturday night cruise with you boys as well.... if we are going to be down there we better make it a huge weekend eh??? so if we can organise it all it would be tops.
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-160276
I'd love to come and have a go but the almighty $$$ has a hold of my pocketbook (figuratively speaking) :) .... I'll probably come and spectate instead. I've been browsing the forum for a while now and have only met Slip so far.
Look forward to meeting everyone...
46n2:burnout:
https://www.sau.com.au/forums/topic/8727-skidpan-day/page/3/#findComment-161520
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
