Fri 14&29th Oct Drive Day, At The Creek $120
Fats, Im 100% for the 14th Oct and if work allows, I will try and make the 29th as well.
I was looking at your drift day, but I have a track day with UAS on Sunday, you know Im not really a drift boy, unless its raining then I will be there with bells on!
Two days in a row out to Oran is a bit much, you only drift on your days dont you?
Edited by Oz GTR02V
  • Replies 134
The form on the website is sent directly to CAMS, there's no facility for the club issued licences on it, and no need for a club rep to fill anything out.
The forms CAMS sends to the club have the "Temporary" slip on them.
When you rock up to one of these days, or any CAMS sanctioned event, as a competitor they should ask for both your CAMS Licence and your club membership card ( to show you are a member of a CAMS affiliated club).
CAN RACE CARS COME , OR DO YOU ONLY WANT ROADIES
PLEASE ADVISE, ie SEPERATE SESSIONS ETC.
Cheers
MIB
All,
If you want to do a track day at Eastern Creek, this is the cheapest option since Moto Concepts were kicked out. It’s a Private practice day run by the ARDC, you will need a L2S or C3 licence to attend.
There are actually 2 days.
Friday the 14th Oct 05 and 29th Oct 05
Details can be found at
http://www.eastern-creek-raceway.com/    Click on Private Practice.
Cost $120 for the Day!
You will need to be an SAU Member and part with $80 bucks for a CAMS L2S licence if you dont already have a CAMS licence.
If you want tickets to the V8's then become a member of the ARDC ($150) and the cost becomes $80 for the day!
Normal non flammable head to toe cloths and a Helmet will get you in, and a road worthy car, they do check them!
These guys run the day very much like a race meet so they can waist a little bit of time being pedantic, but its always good value. With only Cars and L2S they are likely to run alternate 20 or 30 min sessions all day.
Im going to the Friday and Maybe then again on the next one.
Abo was keen as well.
Please let me know if you want to come, and I will contact the creek to let them know the numbers. No need for deposits or anything, you can arrive on the day but they do ask you let them know so they can balance numbers. Please dont commit unless you are 100% coming, no keyboard warriors, I dont want to advise the ADRC we are coming with 15 cars and only have 5 turn up. If you commit, the only excuse I will accept is a dead car or family member.
I will continue to update this post with names.
14th Oct 05
Oz GTR - R34 GTR
azzr32 -  R32 GT
voqi000 - GTS
29th Oct 05
Thanks
Paul,,,I'm up for the 2nd date,,,I can't do the 1st one as my gearbox is at the docs next week.
I wonder if the change to my E/C diff will go smoothly. I bet not.
Don't bother adding me to your list though,,,I'm an ARDC member so I'm all cool.
Neil.
I would really like to go. Could only make the 29th.
how do we pay ? and how many people are going all up?
Is EC a tight track or is it more like wakefield ?
Tommy, if you can make the 29th let me know. You pay at the admin building. So far only you and Neil are the only two for the 29th, it is a Saturday so it will be busy. Its the fastest track in NSW, its a lot longer, faster and still has some slow corners but also some fast ones 180km + at turn 1, it's my favourite track
tight track OR wakefield?? wakefield would be pretty much the tighest track in nsw. EC is a nice change. plus it's far closer to sydney...
I'm hopefully going to make the 14th. i have some interviews to do, but i may be able to reschedule. :D
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
