Originally posted by franks
c&v in sydney did the FC tune.
yeah, i guess it could be a little bit leaner 11.5 is still pretty juicy....from looking at your a/f there isnt much room for bad fuel is there? your not too worried about that?
not really as i always use 98 and the guys and dyno that tuned mine has a 480rwkw GTR running similiar a/f's and he knows what hes doing!:D
around 12.0 or so is perfect a/f for our cars!
  • Replies 41
i had 151rwkw with half an exhaust, filter and 0.6bar...
a friend got 161rwkw bone stock, r33 series2 auto with a manual gearbox conversion *only* ?!?!?
moral of the story? comparing apples and oranges. as much as i'd like to compare it to your figures, i can't. On the same dyno, i could get two different readouts within an hour of each other...
my car is tuned with the afr between 11.8-12.2 this is basically a streight line after the after it drops from running 14.4 in the light load stuff,
franks you would pick up about 15rwkw with a good tune, then some more with boost, get the fuel right and you may have to addjust the timing accordingly.
did u see the HPI magazine R34GTT project car?
they pulled near 200rwkw with basically the same mods u have but 12psi boost!
You should get your retuned man!
I think that 13 is too lean, but it depends where in the power band that it is occuring. Usually 12-12.5 is about as lean as you want to go, otherwise one lot of shit fuel and your in serious trouble.
They may say that your leaning out due to not enough fuel, either buy a bigger pump or fit a fuel pressure regulator.
See'ya:burnout:
Originally posted by nismoR34
Yeah, I recall the HPI r34 project had similar power to Franks, but it was in stock form then. *mental note to re-read that tonight*
yeah i think they said it got around 160kw@wheels in stock form.
I am sure they got around 200kw@wheels with the same mods as franks got. They only blew the turbo when they took it for a run on the track which was after all the engine mods were done, thats when they rebuilt the turbo.
is this all on the HPI's DVD/Video's?
See'ya:burnout:
Yeah thanks...i'm not getting enough fuel. What does a fuel pressure regulator cost (estimate)?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
