  • Replies 101
Out of curiousity what was your terminal speed with the 13.2?
Originally posted by 400HP
I had two passes which were pretty ordinary. 13.2 ET with 2.1 60FT (I know I know....)........I don't think I'll have any more mods in the car by then so I hope to run a 12 in current trim.
As long as I line up VISHES I'll be happy BWHAHA =)
Originally posted by RONIN
ed: myself, carlo, and nick will be there to spectate. I believe Minh is coming out too. not sure if he's running though
ok...you guys know what I look like hahaha...
I'll be there with my tripod and camera...hope to get a few vids...
With a better launch, you could have possibly cracked the 12s.
I mean barely..I'm talking 12.9
You should be getting closer to 1.7-1.8 on the 0-60ft time. Work on your launches. ie. It's a GTR. You want to light up the rear wheels so the front wheels actually do some work. So, rev to rev-limiter if not close to it. Release clutch (quickly, hell sidestep if you want :(:) ).
Make sure to brace neck accordingly. The snap into 2nd could also do some damage (to your neck or car...what ever is weaker)
:D
poyz - I think 107mph or something like that?
Hello Peepz...the impression i had from this drag meet was that SAU would hijack the scene from the rotaries and V8s....but that was not the case :) oh well next time we can turn up in numbers :)
As for my result, I ran a best time of 13.4 @ 103mph @ 1 Bar with 2.0sec 60ft time :)
u ran a 13.4 linus?
damn.....i wanna run mine but im afraid ill run a 16+sec+!!!
i guess ill have to suck it up and give it a go.. :)
Atlantis Aquariums :) heard u were there on sunday, thats my mates shop ;)
I was supporsed to turn up but i was too buggered from carts, ....she was not happi i didn't come :)
Silvias RULE :bahaha:
Originally posted by DON91E
u ran a 13.4 linus?
Atlantis Aquariums ;) heard u were there on sunday, thats my mates shop ;)
yeah i was happy with that run....all night i was doing low 14s..then last run i decided to launch a little harder :)
yep..i was there with my friend...she wanted some seahorses!!!
i thought it was intrusive since they were having a private grand opening party...
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
