  • Replies 101
Out of curiousity what was your terminal speed with the 13.2?
Originally posted by 400HP
I had two passes which were pretty ordinary. 13.2 ET with 2.1 60FT (I know I know....)........I don't think I'll have any more mods in the car by then so I hope to run a 12 in current trim.
As long as I line up VISHES I'll be happy BWHAHA =)
Originally posted by RONIN
ed: myself, carlo, and nick will be there to spectate. I believe Minh is coming out too. not sure if he's running though
ok...you guys know what I look like hahaha...
I'll be there with my tripod and camera...hope to get a few vids...
With a better launch, you could have possibly cracked the 12s.
I mean barely..I'm talking 12.9
You should be getting closer to 1.7-1.8 on the 0-60ft time. Work on your launches. ie. It's a GTR. You want to light up the rear wheels so the front wheels actually do some work. So, rev to rev-limiter if not close to it. Release clutch (quickly, hell sidestep if you want :(:) ).
Make sure to brace neck accordingly. The snap into 2nd could also do some damage (to your neck or car...what ever is weaker)
:D
poyz - I think 107mph or something like that?
Hello Peepz...the impression i had from this drag meet was that SAU would hijack the scene from the rotaries and V8s....but that was not the case :) oh well next time we can turn up in numbers :)
As for my result, I ran a best time of 13.4 @ 103mph @ 1 Bar with 2.0sec 60ft time :)
u ran a 13.4 linus?
damn.....i wanna run mine but im afraid ill run a 16+sec+!!!
i guess ill have to suck it up and give it a go.. :)
Atlantis Aquariums :) heard u were there on sunday, thats my mates shop ;)
I was supporsed to turn up but i was too buggered from carts, ....she was not happi i didn't come :)
Silvias RULE :bahaha:
Originally posted by DON91E
u ran a 13.4 linus?
Atlantis Aquariums ;) heard u were there on sunday, thats my mates shop ;)
yeah i was happy with that run....all night i was doing low 14s..then last run i decided to launch a little harder :)
yep..i was there with my friend...she wanted some seahorses!!!
i thought it was intrusive since they were having a private grand opening party...
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
