hmm ok, so you think i should get r32 i like the r33 a bit more, so im not asking too much questions and boring you, does anyone have a site that give specs of sklines old and new, or just old. that would be helpful, so stuff like power and weight, thanks for any help
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1583863
no, i think you should get the much cheaper R31
you are now at the HIGHEST category of:
- crashing, and either killing yourself or hurting yourself
- insurance premiums
- blowing an engine or gearbox (got the $$ to replace it?)
- wanting to modify (do you really have the $$?)
taking a loan for a first car, if that's what you are doing, is not the best advice anyone could give you...
Warren.
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1583884
Buy my NA r33, its got tv, rims, lowered, 95 model, immaculate, m spec front bar, gtr grill, aftermarket wing etc etc all the usual stuff for 13500 ono? (add is in tomorrows sydney trading post for first time)
If your in NSW this is the only skyline you can get anyway... with the new rules
Dayne
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1583899
Dayne
yeh but you know that will be changed in the near future to include all skyline models.
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1583914
get a twin cam corolla.
3 years later get a turbo skyline
Werd
Twincams rule, use sfa fuel, cost bugger all to maintain and insure. Gold first car.
Oh and i know its just my opinion but dont buy an NA 'line, pointless excercise if u ask me. Better off getting a commo for alot less money.
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1585377
There was another "first car" thread not long ago which recommened waiting before getting a skyline, and get an econobox shopping trolley first. I stand by that recommendation. I drove a hyundai for 2 years before getting my skyline, and I think I appreciate the skyline more because of it.
And does anyone else reckon the twin cam corollas are overrated? Great first car but some people REALLY love them and reckon they've got a rocket or something. A friend of mine claimed his stocker did 0-100km/h in "about 5 seconds" and that he "beats VLs 'n shit".
Dunno why he was so blown away with my stock GTS-T's performance then...
But seriously go for an N/A 4cyl to start with, learn to drive, then you can get a skyline and fully enjoy the performance and handling. Plus with the money you save you might be able to get an R32 GTR in a couple of years!
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1587065
I would also suggest getting a smaller car in the beginning to get some experience and then move to a Skyline.
You won't regret it. Also I think a new P Plater's insurance would be over $2K on a Skyline.
I had a Toyota camry 88 model before. Great car, safe and economical. Especially now when the fuel prices are going through the roof.
I guess the Toyota Corolla Twin Cam suggestion is pretty good.
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1587332
hey mate, Ive got stock R32 GTS-T which im sellin. The engine is untouched. Car is basically stock except the rims. in pretty good nick too. Check the Trading area for more info if you interested. $11500 :D
Edited by nz_kastaway
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1587480
haha, well now these guys are giving me gr8 ideas and im now just checking out sum corollas and golf GTi's, maybe a mazda or sumfin, i think you can get a 626 2.0L turbo or like 2.1 N/A, yer im not really shore
just sold my NA TX5 2.2L
https://www.sau.com.au/forums/topic/87680-first-car/#findComment-1589508
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
