Have the following items for sale:
- Enkei NT03 18 x 10 wheels suit 33/34 GTR, in excellent condition, recently painted black, with Dunlop D01J 265/35/18 semi comp rubber, not much tread left but still got a few track days in them...
PRICE $2500 ono *SOLD*
- R33 GTR standard turbos done approx 70,000kms, in good condition, no shaft play..
PRICE $700 ono
- R33 GTR standard radiator, great condition
PRICE $300 ono
- HKS front pipe suit 32/33/34 GTR, good condition
PRICE $300 ono **SOLD**
- R33 GTR dash cluster with 74k km's
PRICE $250
- R33 GTR triple meter gauge set
PRICE $150
Parts are located in Melbourne, will ship interstate at buyers expense...
Please PM or reply in this thread....
PRICE $2500 ono
- Brembo F50 Upgrade kit suit 32/33/34 GTR, 355 mm rotors in good condition, comes with brackets and everything else to bolt straight on. Has race pads (unknown, blue in color) and also EBC green stuff for the street...
PRICE $2800 ono
PRICE $700 ono
PRICE $300 ono
PRICE $300 ono
PRICE $250
PRICE $150
hey malaka,
waht offset are the enkeis.
fullo - If you don't know what standard R33GTR turbos look like, then they're not for you....
You can get a general sense of the condition of turbos, by looking at them.
So ur saying if the bearings were f**ked in them and I cleaned the turbos so they looked clean and brand new does that mean they are in new condition????
Hey no need to get all defensive, I'm just saying there is some legitemacy in his request. No matter how much you clean turbos, you can tell roughly how old they are, or how much they've been used by looking at them.
Not getting defensive mate, but I can't see how looking at a pic on the computer tells u how good the turbos are....
im with you on that one....
back on topic what offset are the wheels?? +22 or there abouts??
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
