  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I couldn't warrant a new thread so I thought I would just post here instead..... I'm excited as I have just ordered my HKS cooler and Apexi AVC-R from Nengun... :)
Hehe in a few weeks I should be moving along very nicely :burnout: ... Can't wait for the next croose so I can meet up and see some of these cars you are talking about!!! :uh-huh:
Brett
Skyzerr, What suspension was it, Koni adjustables?
MrGTST, Nice way to spend a few K, should be worth it for the difference in performance. Hope it all goes smoothly. The next cruise is this Sunday, and then one the following week. Hope to see you there.
See'ya:burnout:
I believe the 255x40x17 refers to:
255 - Width in "mm" of the tyre
40 - The profile of the tyre. I.E the smaller the number the thinner the tire is.. I hope that makes sense
17 - The size of the rim in inchs
I hope that makes sense :(
Skyzerr, sorry about that dude, I was trying to reverse park the car, and pressed a little too hand on the phone. Couldn't ring you back cause I have no money left on the phone. Sorry.
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
Macka brought the baby oil and I brought the whip, was a good bonding session.:lol:
See'ya:burnout:
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
