  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I couldn't warrant a new thread so I thought I would just post here instead..... I'm excited as I have just ordered my HKS cooler and Apexi AVC-R from Nengun... :)
Hehe in a few weeks I should be moving along very nicely :burnout: ... Can't wait for the next croose so I can meet up and see some of these cars you are talking about!!! :uh-huh:
Brett
Skyzerr, What suspension was it, Koni adjustables?
MrGTST, Nice way to spend a few K, should be worth it for the difference in performance. Hope it all goes smoothly. The next cruise is this Sunday, and then one the following week. Hope to see you there.
See'ya:burnout:
I believe the 255x40x17 refers to:
255 - Width in "mm" of the tyre
40 - The profile of the tyre. I.E the smaller the number the thinner the tire is.. I hope that makes sense
17 - The size of the rim in inchs
I hope that makes sense :(
Skyzerr, sorry about that dude, I was trying to reverse park the car, and pressed a little too hand on the phone. Couldn't ring you back cause I have no money left on the phone. Sorry.
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
Macka brought the baby oil and I brought the whip, was a good bonding session.:lol:
See'ya:burnout:
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
