  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I'm thinking of opening a Ninja whoring school, get to jump from the shadows, whore, and be gone before anyone notices.
See'ya:burnout:
Ahhh that actually made me laugh out loud... Now everyone is staring at me ... :)
Ahhh but is it trully a whore if no-one is there to see it?
Getting mods is always exciting!!!! I know because my parts from nengun should arrive sometime next week.... then find someone to fit them and away we go :burnout:
Yeah it definately will, boost controller is one of the best things you can get. Not cheap though.
What other mods have you already done?
See'ya:burnout:
Hmm I am assuming this one is directed at me.... :)
I havent touched the car since I have had it, but from what I can gather its got a full turbo back exhaust ( I beleive HKS but would like to confirm this at some stage ) , a HKS air pod and some small suspsension/handling upgrades.
It seems to have alot of go for what it has though. It makes me wonder if there is something else that I cant see that has been done to it???? Even against other skylines with similar mods I tend to pull away, especially in 3rd. That gear is superb....
haha yeah
that rear brake light globe
will actually makemy car stop looking like a queer
it's funny when u only got three stove plates lightin up
i could only cook three eggs this morning
instead of the usual four! lol
adrian
the brake pads add 30 hp
guage 25
pillar mount 10
machined discs 10
and rear barke light a whopping 20
plus the full service provides me with another 10
so all together a 105 hp gain!
which should put me in the 12's easy!
don't forgot my three stickers down the side!
adrian
On a more serious note though.... getting things fixed like the brake lights fixed are well worth it.... Those are the sorts of things that can get the cops attention pretty quickly.... unless of course if you are sliding donw the road sideways or something like that, then the brake light is probably negligable :)
yes i love to get my baby in tip top shape
as paul says some of us drive very hard!
lets just say my drive home from work
last night was rather fun a risky!
hehe doing launches at the quite part of welshpool rd!
taking corners rather fast lol!
ahhh the life of a skyline owner!
adrian :)
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
