  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
3040 bigger then 3037 right?
yeah i fink i should strengthen my box though
coz like i dun want it blowing when i start gettin up to the power output i want:)
so roughly i am after 300-400hp
do i really need to get a trust plenum for that sought of power?
adrian
Adrian,
No you don't need a Trust plenum for that, but it makes it easier to get that power. 3037 is HKS variant, they make minor adjustments to trims etc, over the garret unit. Both are around 550-600hp.
The box should be fine, how were you going to strengthen it?
See'ya:burnout:
what i meant
by strenghtening
was geta stronger box
u know like them aftermarket shifters?
but then i would rather spend the money on getting a manual conversion done ahh well auto will do for now, ah so ur using a garrett turbo smae specs as hks turbo?
but cheaper am i right?
so ur saying to build up revs in a auto, have the car in drive, and keep foot firmly on brake while reving then let gooff brake when it's time to roll?
adrian
Bully,
Seeing as your up, and I don't trust Adrian's opinion, can i ask you a serious question?
With these SAU shirts, would you like for us to organise one of each to be made so that all those interested could see what they are getting before they buy? I was thinking about one mans(L) and one womans(M), it would give people a better idea about sizes aswell.
See'ya:burnout:
Adrian, Yeah that's the best way to launch an auto.
Garret sell HKS some of there turbo's, which are only sold by HKS, therefore you cannot get a Garret turbo which has the same specs as the HKS one. But seeing as the HKS one is over $1000 more then I don't see where the real benefit is, I'd rather go for the Garret one which produces similar power.
See'ya:burnout:
troo troo good point
yeah i read bout garret providing hks turbos
and it also said who the other jap houses
got their turbos from :)
okay so the trust or subzero plenum is goin to be a 11th hour decision for me as well ;) argh i hate decisions
adrian :)
Originally posted by GTS-t VSPEC
Bully,
See'ya:burnout:
Sorry had work to do ---- i think once a few see them more will want them thats the normal thing that happens i go along with that
Originally posted by Adrian_perth
what i meant
by strenghtening
adrian
i launch mine in low then change up through 2 nd then to drive like a manual - i found i get better times that way,
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
