  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
3040 bigger then 3037 right?
yeah i fink i should strengthen my box though
coz like i dun want it blowing when i start gettin up to the power output i want:)
so roughly i am after 300-400hp
do i really need to get a trust plenum for that sought of power?
adrian
Adrian,
No you don't need a Trust plenum for that, but it makes it easier to get that power. 3037 is HKS variant, they make minor adjustments to trims etc, over the garret unit. Both are around 550-600hp.
The box should be fine, how were you going to strengthen it?
See'ya:burnout:
what i meant
by strenghtening
was geta stronger box
u know like them aftermarket shifters?
but then i would rather spend the money on getting a manual conversion done ahh well auto will do for now, ah so ur using a garrett turbo smae specs as hks turbo?
but cheaper am i right?
so ur saying to build up revs in a auto, have the car in drive, and keep foot firmly on brake while reving then let gooff brake when it's time to roll?
adrian
Bully,
Seeing as your up, and I don't trust Adrian's opinion, can i ask you a serious question?
With these SAU shirts, would you like for us to organise one of each to be made so that all those interested could see what they are getting before they buy? I was thinking about one mans(L) and one womans(M), it would give people a better idea about sizes aswell.
See'ya:burnout:
Adrian, Yeah that's the best way to launch an auto.
Garret sell HKS some of there turbo's, which are only sold by HKS, therefore you cannot get a Garret turbo which has the same specs as the HKS one. But seeing as the HKS one is over $1000 more then I don't see where the real benefit is, I'd rather go for the Garret one which produces similar power.
See'ya:burnout:
troo troo good point
yeah i read bout garret providing hks turbos
and it also said who the other jap houses
got their turbos from :)
okay so the trust or subzero plenum is goin to be a 11th hour decision for me as well ;) argh i hate decisions
adrian :)
Originally posted by GTS-t VSPEC
Bully,
See'ya:burnout:
Sorry had work to do ---- i think once a few see them more will want them thats the normal thing that happens i go along with that
Originally posted by Adrian_perth
what i meant
by strenghtening
adrian
i launch mine in low then change up through 2 nd then to drive like a manual - i found i get better times that way,
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
