  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Adrian - something you should quickly learn - is that the most productive place at any tertiary institute is the tavern... trust me I spent 4 years there and still graduated!
i didn't but i spent to long in the uni tavern hehe
but pot black helped me graduate tafe ;)
