  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hell
i wasn't on the forums for a few days
and when i came back
i read all about paul,nizmos and who ever else was involved
talking bout animals and kinky sex i was like whoaaaaaa!
heheheeh
crazy people
anyways i am off to tha gym
catchas l8r!
adrian ;)
