  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
actually i was taught that marie currie stuff in PEAC when i was like 6 or something - i dont think it seeped in very well too busy showing my gymnastic skills to the other schools on the bars at recess haha I swear i fluked that test!
Originally posted by Nizmo
hahaha battery operated boyfriend hahaha so many things too say but i think i should just keep the mouth shut and save myself
Yep , don't require stimulation , always ready ( or eveready as they say ), don't have to kiss it , no bad breath ,comes in handy pocket size to OMFG where is THAT going.
Hmmm your right , you girls don't need us.
why does everyone think im dating paul ive even gotta set Dan straight tommorrow at work - im like what a weird question where on earth did u get that from!! Battery operated boyfriend haha isnt so bad by the ken is describing it - should be a salemen for barberellas ken haha!!!
hey isnt there still US legislation (louisanna or something like that) that makes it illegal to have sex hmmm i forge tthe conditions - it could be in public (but isnt that illegal anyway not to say we all haven been guilty of it) I cant remember (damn peroxide seeping thru again) but its some real strict rule!
Only if I can do the personal demo's:D
Cheers
Ken
Who said you were dating pwptf ??
I thought you had WAY more class than that anyway.lol
Cheers
I'm gonna cop it
Ken
you mean it is illigal to have sexual inercourse in the car...?
in the state of Arizona, it is illegal to sell cabbage on sunday
cheers
Joe
hahaha now the personal demos ken i have to see *what ken can do with a battery operated "boyfriend" has to make some money in videotape* haha
It's not WHAT I can do , it is WHO I can do that will make the money.
Geez 6 pages and no animal sex yet.
Have worked out by a method of deduction ( Elementary my dear whats on, hehe) that the animal sex problem is
pwptf
Cheers
sherlock
Ken
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
