  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have no prob with 3 am starts. leaves u the rest of the day to do what u want :P
better than what i do now. 4-12 on a sat night then 8-4 on a sunday morning
ass
i managed to get the night shift last sunday for the cruise. and i got tommorow off. so if ne ones interested we are extracting the bolts that have snapped of in kyms manifold. come round and well drink and look at his car some more
Psiker
when we replaced his turbo gasket. we noticed some bolts in his manifold were loose. on closer inspection we found out the were sheared off (snapped inside the manifold. actually more inside the engine.
so we need to remove em and replac em
V-spec - i have no probs with that pm me ur mobi and ill msg ya one day
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
