I prolly saw you after the crash - but i don't remember much from that hahaha
Who cares if people think they are ricey. Jeez - everything on everyones car prolly has something ricey about it! I have a recaro seat phone holder.... ohh its ricey hahaha if you like it then do it. Are you doing it to impress other people or for yourself?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
the things with neons.. the attract cops like cops to a flame
but as much hassle as mr plod gives you if u are parked they are not illegal
driving with neons on is illegal as it is a wrong colour form of illumination from outside your vehicle
technically you are allowed to have any for of illumination inside your car. Also you may have them on while u are in a stationary postition
laws have so many loopholes
Psiker
as i said illumination inside the car is fine. the cops will hassle you and maybe licky you. but the engineers will say they are fine. surprisingly most cops dont know all the laws. tyhey just go on a loose version in their minds of what is right and wrong. the law says any illumination other than authorized outside vehicle is illegal except while vehicle is stationary. they tend to forget the last part
Psiker
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
