yeh, that's what i thought hey....
it'll hit 7psi at like 6500rpm tho, but builds up DAM slow... hehe, go the fuel saving hey.
It better be dam stronger hey.
My plans next are
Clutch (still deciding on 2200lbs or 2500lbs)
S-AFC
FMIC
more boost, hicks style
cam gears etc.
tried to change my gearbox oil on the w/e with no luck. those dam bolts are TIGHT AS!
ho hummm... goddam car.
gonna change the diff oil tho soon. if i can get the dam bungs out!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah, I helped do Skyzerr's diff oil, but needed Ken's help to loosen the bolts, more know-how than strength required.
The 2200lb clutch sounds like the go, do that before anything else or the new power would kill it off.
It's all just money, you can always earn more:p
See'ya:burnout:
boostzor whats a postache?
hehee
don't mind my stupidness
paul:- trust frontbar, trial side skirts(when i actually buy them), and no it ain't a high gt wing it is lower then others i have seen
i ain't a fan of the high ones! this one looks sleek! and stylish (it's black)
adrian :)
yeh i think ure right there vspac, the words are all too bunched together and make it hard to read.
like whne u turn stuff
around so that they dont really make
sense unless u read em properly
"im goin to low the mawn"
