yeh, that's what i thought hey....
it'll hit 7psi at like 6500rpm tho, but builds up DAM slow... hehe, go the fuel saving hey.
It better be dam stronger hey.
My plans next are
Clutch (still deciding on 2200lbs or 2500lbs)
S-AFC
FMIC
more boost, hicks style
cam gears etc.
tried to change my gearbox oil on the w/e with no luck. those dam bolts are TIGHT AS!
ho hummm... goddam car.
gonna change the diff oil tho soon. if i can get the dam bungs out!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah, I helped do Skyzerr's diff oil, but needed Ken's help to loosen the bolts, more know-how than strength required.
The 2200lb clutch sounds like the go, do that before anything else or the new power would kill it off.
It's all just money, you can always earn more:p
See'ya:burnout:
boostzor whats a postache?
hehee
don't mind my stupidness
paul:- trust frontbar, trial side skirts(when i actually buy them), and no it ain't a high gt wing it is lower then others i have seen
i ain't a fan of the high ones! this one looks sleek! and stylish (it's black)
adrian :)
yeh i think ure right there vspac, the words are all too bunched together and make it hard to read.
like whne u turn stuff
around so that they dont really make
sense unless u read em properly
"im goin to low the mawn"
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
