yeh, that's what i thought hey....
it'll hit 7psi at like 6500rpm tho, but builds up DAM slow... hehe, go the fuel saving hey.
It better be dam stronger hey.
My plans next are
Clutch (still deciding on 2200lbs or 2500lbs)
S-AFC
FMIC
more boost, hicks style
cam gears etc.
tried to change my gearbox oil on the w/e with no luck. those dam bolts are TIGHT AS!
ho hummm... goddam car.
gonna change the diff oil tho soon. if i can get the dam bungs out!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah, I helped do Skyzerr's diff oil, but needed Ken's help to loosen the bolts, more know-how than strength required.
The 2200lb clutch sounds like the go, do that before anything else or the new power would kill it off.
It's all just money, you can always earn more:p
See'ya:burnout:
boostzor whats a postache?
hehee
don't mind my stupidness
paul:- trust frontbar, trial side skirts(when i actually buy them), and no it ain't a high gt wing it is lower then others i have seen
i ain't a fan of the high ones! this one looks sleek! and stylish (it's black)
adrian :)
yeh i think ure right there vspac, the words are all too bunched together and make it hard to read.
like whne u turn stuff
around so that they dont really make
sense unless u read em properly
"im goin to low the mawn"
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
