  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
you can talk kym
look at the girl u got and u keep chasing any skirt that walks by
ur nuts
chasing ?
it's more the use of a cattle-prod that shocks my fellow peers (pun intended)
my gf doesnt mind if i look at other chicks, as long as i come back to her! *swish!*
