Originally posted by Micko
Still can't figure out why the reference is out for base timing, but got the CAS at about midpoint which should ba around 20 degrees - no pinging as best we can tell.
Hopefully put the car on a dyno tomorrow to check a couple of things are normal & then if all is good I should be able to put the problems behind me
*crosses fingers*
yea , lets hope so .
Have you had the CAS in the same place before ?
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Makes me wonder whether there ever was a problem with the knock sensors - who knows as long as it stays away, I don't really care.
Must say I have learnt a lot about the car throughout this process, so that definately makes things worth while (kind of!).
Well there must have been a prob somewhere or it wouldn't have kept showing a code
Cheers
ken
Nizmo - I dont know either, I'm just repeating what other people have told me:)
Shaddup and listen.
Geez , a women comes on and Micko goes off the topic.
Remember , your married:D
Cheers
Ken
i tell ya theres some real crap on TV!! Mum hijacked the computer there wasnt much happening so i told her she was welcome too.
Bloody family - having to share - glad im an only child - with siblings it would be worse!!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
