Hey Micko , answer the damn question and stop dreaming of Niz.
Has the bas3e timing changed and is there any codes.
* young whipper snapper , bludging in class *
Cheers
old and and grumpy
Ken:D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yep - no codes, timing presently about 32 deg.
Must admit that after changing the rear knock sensor on the weekend I haven't had any problems from the sensors
*touches wood*
so let's assume that it was faulty - could always put on the front to confirm, but I might get things right first.
Originally posted by skyzerr33
oh boo hoo ken
cause i can i  will so deal with it mr
ooh , isn't he the keyboard warrior
*no , don't mention warrior or satr wars will return*
Are you at home ??
Cheers
Ken
*touches wood*
What ?? are you a glutton for burnt arm , scratches and dirty nails.
No codes , base timing OK
Don't phuck with it man !!:P
Cheers
Ken
haha kicking the old man out way to go - its not too bad here cos my parents have a place in bunbury too - so they are only here half the time - but since renovating this house lately they are here a lot more often! I've lived with someone haha its an experience i'll say that!
You're right - but I'm also a very curious bugger!!!
Plus the front one is a piece of cake to change - I'll show you one day if you like young grasshopper:)
...probably wont bother though cos what difference does it make
Hmm very curious tho.
As I said there MUST have been a prob or the puter wouldn't have come up with a code.
Cheers
Ken
haha no point opening my purse - anything that was in there is on the wheels anyway :P by the mostly stockness of my car its obvious that there wasnt much in the purse to begin with anyway!
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
