Originally posted by Nizmo
haha just my dad - gotta take someone to pay the bill :P
Nah i dont get taken out to dinner anymore - nobody loves me *sniff* haha
Hmmm , 5 guys dive for niz's PM button .
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
geez guys im actually not the man eater i appear to be haha i am quite sweet - my dad mentioned tonight how i constantly used to give in to the ex <- Dad didnt like him much.
But i am as stubborn as all hell and like to get my own way - but i reckon the fairy could pull off bigger tantrums than me!
Heeeheeeeheeee
I knew if I persisted with the fairy bit it would catch on.
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Ken,
See, we managed to fix something without your help:p
See'ya:burnout:
What , so the 2 phonecalls don't count as assistance ?
Cheers
whats this , the RAC:D
Ken
Originally posted by skyzerr33
haha we can have a tantrum contest staring pwptfwbgaw, niz and ken
kylie can judge as she sees tantrums all day at work
Ok , I'm gonna have to ask
Whats the wbgaw on the end ??
Cheers
It's gonna be rude
Ken
Originally posted by Micko
Yeah sorry about that old chap - thanks for all your help again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again, again wise silent Ken...
Nah , just kidding.
It's all part of the lifetime after sales service warranty.lol
Cheers
Ken
Ken - you dirty man go get some tissues
Paul - bloody oath I like reassuring when I'm talking about an expensive piece of machinery... never can be too sure
don't worry micko, naomi prefers the real thing to the dildo u got her for xmas
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
