  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Select Australasia - hey ask 25GTT how he got his job he works the floor below me in IT. Also contractor.
Hey gotta go for 15mins I'll be back later. Save the interesting talk for when i get back ;)
Car dealerships are ok - just a lot of seediness.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
