  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Niz,
Don't be sad, you can join us for a drink, were going to a strip club:p
See'ya:burnout:
AHAHAHA!! I have 2 friends which are girls whose boyfriends go there somtmies..... they go with them and they say there is quite a few other girls there aswell! So you have no excuse Nizmo.... boys if you wish hard enough and ask politely maybe Nizmo might show yas a thing or 2! aahahah!!! Oh maybe i should shutup now.....
Oh and Dan.... WRX cruise... man the dark side of the force really have you now don't they! are they as good as our cruises? Bet you can't stick your head out of there sunroofs at 80 km
h like we did in mine! so THERE!;) :bahaha: :shake:
Originally posted by Nizmo
hahaha i would make those girls look like novices!! haha ;)
Ouch.... where to start on a comment like that :D
Hmmm well if you are offereing to show us some tricks just give me a place and a time and I will make myself available... ;)
